This is s question for Mac and IOS
Is it possible to have a 1 to 1 relationship that TF will enforce.
I have a Customer Totals form which should exist 1 time for each customer, they are linked by a customerid. I can control the creation of the form when I create a customer.
On Mac I can prevent a second Totals form by locking it so user can not create new. But upon export to IOS this does not seem to be exprted.
On IOS I can not find a way to prevent usres from click + to add new total record.
Thanks in advance
Bernie
PS. I do nto want to combine the Customer and Totals on one form as it is too cumbersom to view especially on IOS I have various categories of totals I want to display on separate Form
PS. I do nto want to combine the Customer and Totals on one form as it is too cumbersom to view especially on IOS I have various categories of totals I want to display on separate Forms.
Hi Bernie,
I moved your posting to the Using Tap Forms forum because your question doesn’t have anything to do with scripting.
Tap Forms does not support a one-to-one relationship. It has One to Many, Many to Many, and Join.
The iOS version doesn’t yet support the Access Controls function, which I think you’re referring to .
Thanks,
Brendan
